As most of us are saying, and was confirmed to me by Bloxsport, 15mm will not clear the Uberturbines without trimming the factory studs. It’s not the problem of the spacer itself, it’s the length of the factory studs that will hit the back of the rim and will not allow the wheel to sit flush against the wheel spacer. Most say 18mm minimum is required to clear the wheels.
Danny is terrific so I don’t know. He told me the would fit mine too and they didn’t. Maybe you will get lucky. I would be surprised if they fit the Uberturines. Doesn’t hurt to try. To be clear I do not have Ubers but I have forgestar with nearly the same spec.
15mm Aspira Spacers will clear M3P Uberturbines.
Both of these cars are lowered and using 15mm Aspira Spacers all around.
Wheels can be the same spec but the hub pocket clearance aren't equal.
Danny
