There are at least 4 of usMe too. Maybe we are not a rare breed after all.
Actually 5 now! I have just asked Octopus for a quote to see how it compares to the deal I got from Pink.There are at least 4 of us
Now that i have a estimated delivery date, this video turns up to suggest I should have stayed with LR or P-![]()
Is it just the Tesla's 20" wheels? I have 20" in my 911 and Q7 and they seem fine.
It's such a subjective thing. I've driven both the SR+ and the P+, and I didn't find the P+ suspension to be dramatically worse at absorbing bumps and imperfections in the road. The economy is the only real issue for me, but like you, I couldn't justify not changing.They're not wrong!
I really wanted a P- as I simply couldn't live with the software crippled performance of the LR AWD out of principle. But I also refuse to now pay £900 MORE money for a white P- vs a white P+
So I'm getting the cheaper P+ and will probably put the £900 saving toward a set of 19" wheels (either the Tesla sport wheels when they become available or some nice aftermarket wheels). I'll sell the 20" wheels on ebay if I haven't destroyed them already!
If the P- comes back as a lower priced option before delivery (should be £2k less on current pricing) I may switch back, but it would be a close call for such relatively little saving, as I do prefer the bigger brakes (reviews suggest they have better pedal feel) and track mode could be fun (allowing a bit of sideways slip).
They should really make 19" wheels a no-cost option on the P+ as that would solve all my current dilemmas!
I've read several reports now of people damaging the 20" wheels, so I guess this could be an issue, but I've had to deal with that on most of the performance cars I've had. The Tesla will be no different. Bigger wheels equals more expense, but also better handling.
I'll be coming from an F10 M5 with adaptive suspension, and I found the comfort on the P+ to be very comparable to the M5. It's perfectly acceptable, and the M5 has some of the best suspension (for comfort) I've had in a performance car. Granted, it's not as compliant as the suspension in the SR+, but then I don't want that.It's all relative to what shite ride quality you are already used to! That part is certainly highly subjective, but I can believe the ride quality is still "acceptable".
My real concerns are road noise (already plenty of videos showing much higher road noise on 20") and rim damage from potholes and kerbs.
Better handling on 20" you reckon? I very much doubt it compared to 19" or even 18" on decent rubber. But the PUP does give you the uprated brakes, slightly lowered ride height and track mode, which will make it feel more "sporty" at least.
When you have a car as heavy as the Model 3, you do need slightly stiffer damping to ensure better body control. I'm happy with the compromise that Tesla have chosen for the P+.
As for handling on the 20's, then they are a lower profile tyre, so less sidewall flex which translates to better feel when pushing on. There's not much in it when it comes to contact patch size between the 18's, 19's and 20's. As you say, the rubber will be the biggest differentiator.
Like you, I'm tempted to look into a second set of wheels. I'll aim to get the lightest set I can that will fit over the brakes. Should mean better performance (lower 0-60 particularly) and greater effiiciency. All depends on what the lease company/insurers have to say, though. I guess it counts as a modification, which they both seem to frown on these days.
You might well be right about that one. I've not seen anything to indicate they're different.True, but I doubt the P+ has stiffer damper valving than the standard car. If it has stiffer springs on the same dampers then it will actually have less damping than the standard car (as the damping ratio will go down). If it is merely lowered by 10 mm, as I suspect is the case, then damping will be the same, but the lower CofG will help the handling a little. No idea if they uprated the anti-roll bars on the P+ but I doubt it.
On that one, I'll defer to your greater experience. I'd have been quite happy to take the 18" Aeros if Tesla would have allowed me the other bits of the performance pack. Sadly, it's not to be.My extensive motorsport engineering experience and discussing with top level race tyre designers has led me to believe that the optimum sidewall profile is more like 40 or 45 profile and certainly not down at 35! It's basically a trade off between sidewall stiffness, mass, grip and predictable handling on the limit. Ultra-low profile tyres tend to break away more suddenly at the limit with obvious negative consequences. So I would have no worries about fitting 18 or 19" wheels with sticky rubber for ultimate handling on road or track. I think the 20s are taking it too far for just for the sake of marketing cosmetics. But that's what the market demands, so that's where we are!
That's what I've been reading too. I watched a YouTube video where the guy had to do some machining to get things to fit. Can't seem to find it now.Lighter is good, providing they don't flex like crazy, but the returns for your cash are going to be very minimal. Light and strong wheels = ££££. By far the biggest influence on your 0-60 will be the road surface i.e. grip level off the line. But yeah, a nice set of forged lightweight 18s or 19s would be nice to have. I don't think brake clearance is a big issue as there are already aftermarket 18s that do fit the P+ brakes. I think the problem is actually related to a revised lip on the hub rather than the physical size of the calipers, but I haven't seen it personally. But there are photos of people fitting even bigger brakes than the P+ in the US, so that backs it up.
I will stick to the P+
This also looks interesting:
Nothing can get close to a P Tesla on public roads due to the crazy 0-60 time, but dare I say it.....Its all a bit too civilised and composed.
If you enjoy a bit of an adrenaline kick for driving fun I still think RWD is key. 37k in driving various Teslas am now really missing some back end wiggling.
I think Tiff gets straight to the point (as usual), the noise/gear changing I don't miss, but I do miss the fun of feeling the car slide out, putting down the power mid corner and feeling the back end do a wiggle, having to actually give the loud pedal respect rather than just treat it like a playstation game pad. Anyone whos driven a good RWD car will know what am on about.
AWD Tesla's are so composed sometimes I even miss my old Leaf, which would understeer and than torque steer and even had some lift off oversteer!! In our X it really is a case of stab the right foot and see how quickly you reach license losing speeds regardless of road condition, weather, adverse camber. The car has so much grip by the time your actually pushing anything close to its limit your travelling so fast and so out of your driving talent zone its the fear of having a multi car accident that than kicks in. But I think thats the same 'issue' with things like GTRs, RWD for the win, as Bjorn would say.
Personally my ideal 3 is LR RWD, P cars are much quicker but I'm now realising a quicker car isn't always the fun car. Its all academic sadly Tesla are refusing to sell that to us at the moment.
I'm thinking you might have been off planet earth for the last couple of weeks.Have Tesla changed the UK spec options again? Unless I'm imagining it I thought that after last big change in the configurator when you selected the Performance option you then also could select the performance pack as an add-on (hence P- and P+ ). But when I look today the Performance option includes the Performance pack - so you can no longer have the 3.2s performance without the 20" wheels?
Maybe I'm just getting confused...
