Mono-block Forged Wheels $470 each for the Model 3
Xenoilphobe
5,181
5,218
DC Swamp
Wonder if we could get a group buy for these?
I think I found my mono block forged wheels --- $470 each and only 18 pounds ..
Titan 7 T-S5 Wheel - 18x9.5 / 5x114.3 / Offset +40 (Satin Titanium) | Evasive Motorsports
or these
Titan 7 T-R10 Wheel - 18x9.5 / 5x114.3 / Offset +40 (Machine Black) | Evasive Motorsports
Just need a hub ring to bring it from 73mm center bore to 64.1mm center bore -
Muteki Hub Ring 73mm / 64mm | Evasive Motorsports
Lifetime structural warranty too!!!
3.6 lbs lighter than bare aeros and 5 lbs lighter than the stock 18 inch with aeros on - specs here - Titan 7 Forged Wheels - Forged For All
Stock size is
  • Size: 18X8.5"
  • Offset: +40
  • PCD: 5X114.3
  • Center Bore: 64.1mm
  • Weight: 21.6 lbs (Without Aero Cover), 23 lbs (With Aero Cover)
  • Lug Nut Spec: 13/16 Hex, 14X1.50 Thread
  • Lug Nut Torque Spec: 129 lb-ft
  • Price: No Charge
  • Tire Spec: Michelin Primacy MXM4, 235/45-18, 98W
  • Details: This is the original base model wheel that comes with every Tesla Model 3 free of charge.
Hrm. I like those a fair amount. Is there any disadvantage to the center bore not being the same and needing the adapter?*
*I know nothing about aftermarket wheels.
No - this is just a spacer to close the gap... also I am trying to find out if they will make the Model 3 exact spec with the center bore at 64.1 like stock....
Hrm. I like those a fair amount. Is there any disadvantage to the center bore not being the same and needing the adapter?* *I know nothing about aftermarket wheels.
Nice wheels, but hub-centric would be much better... shop around for a forged wheel that fits without an adapter. :cool:
Reactions: Xenoilphobe
or these
Stock size is
  • Size: 18X8.5"
  • Offset: +40
  • PCD: 5X114.3
  • Price: No Charge
Recommend 19s with a bit more offset. The front and rear view of the M3 is the least attractive angles but a wider stance does help.
