MPP Comfort Coilover reviews?
Discussion in 'Model 3: Driving Dynamics' started by WhiteStarSal, Dec 19, 2018.
  1. Skione65
    Skione65 Member
    Kentucky
    #361 Skione65, Aug 18, 2019
    @dfwatt,
    Looks like Hankook Ventus V12’s. Nice rims as well. I like them.
    Ski
  2. Eltroneus
    Eltroneus New Member
    San Diego
    Yes staggered, here is the setup.
    Wheels:
    HRE FlowForm FF01 Wheel Package for 2018 Tesla Model 3
    Size: Front - 20x9.5 +35ET (Flat Face), Rear - 20x10.5 +45ET (Concave Face)
    Tires:
    255/30/20 275/30/20 Hankook Ventus
  3. SD_Engnr
    SD_Engnr Active Member
    San Diego
    Looks good.
    Confirm that they installed everything properly. Besides messing up the install, and then installing it too low, they missed a rear rubber isolator on my install.
  4. Eltroneus
    San Diego
    Ok, will do. I'm going to go back and raise it back up to just about .25 - .5 inches under stock height as I need the clearance on the streets.
  5. BYE FSL
    BYE FSL Member
    L.A.
    I am very happy with my new Comfort Coilovers from Mountain Pass Performance and KW. VERY happy. The car is definitely more comfortable and better handling than stock.
    They were installed yesterday at West End Alignment in Gardena, CA, which I also highly recommend. Chris is fanatical, meticulous, prompt, and communicative.
    The vibrations coming into the cabin are reduced. “Muted” is the word that immediately came to mind. “Muffled“ may apply. I was aiming at road defects and smiling.
    It is quieter. Sound is vibration, so less vibration means less noise in the cabin. I never heard anyone say that. It was a surprise to me.
    It clearly corners much better, with less body roll. Clearly. More smiles. The flatter cornering adds to the comfort as well as the excitement. I don’t know why MPP doesn’t claim this. There must be ways to measure it so they can. If there’s no app for that, how about a bowl of water on the floor, and measure the spill?
    Of course it looks better. It looks right. My installer agreed with the MPP height recommendation. Mine are set a few mm above the MPP recommendation to allow for slight settling.
    The stock setup was annoying. Now my M3P rides like the German cars I am used to. The only downside besides the time and money is that I will probably wear out my tires faster now that it corners better.
    • Informative x 2
  6. MountainPass
    MountainPass Vendor
    Toronto, Canada
    If you have any nice photos of your car, we would love to add it to our customer's builds/testimonials section. Glad to hear you love your car even more than before, that's our goal!
  7. cyoma
    cyoma Member
    MN
    Any body from Minneapolis area, installed this, willing to provide a test ride ?
  8. Eltroneus
    San Diego
    How low do you have yours set at?
  9. dfwatt
    dfwatt Active Member
    FL
    So you have the Dual Motor Performance version correct? With the stock 20 inch wheels? It sounds like you experience the car as somewhat better isolated in terms of the small grain and harshness of the road? How about over larger impacts? I'm toying with the idea of getting the Comfort coilovers for my wife's car. I have the sports coilovers on mine which I love, but that's overkill for her. Getting better ride and handling if that's possible while fixing the ride height issue seems worth it. Do you have any pictures that you would feel comfortable posting? Thanks in advance!
  10. hocr
    hocr Member
    Anyone in the Bay Area willing to give a test ride on the comfort or sports? :)
  11. zhu-
    zhu- Member
    NJ
    @BYE FSL Does the car also dip and dive less on hard braking/accelerating with the MPP comforts?
    Does ride height also affect how stiff they are or is that constant?
  12. MountainPass
    MountainPass Vendor
    Toronto, Canada
    The ride height doesn't affect the ride unless you are at the extremes of adjustment
  13. Lucy903
    Lucy903 Member
    Anyone interested on a brand new never been installed still in the box KW variant 3 for a RWD? Pm me if interest pick up only in the SF Bay Area. Part # 35287006.
  14. BYE FSL
    BYE FSL Member
    L.A.
    Sorry, I have no input on that for you. I didn’t notice dipping and diving prior. However, since there is less side roll, I would guess there is less to and fro movement also, since it is governed by the same mechanism, no?
  15. dfwatt
    FL
    There is definitely less dive with the sports coilovers, but I suspect there's somewhat less with the Comfort coilovers too. The big difference is the shocks are not adjustable, and the spring rate is a little firmer on the sports coilovers. But a lot of brake dive resistance is actually coming from the shocks and not just the springs.
