MYP: Spacers on 21” Ubertines
Does 15mm fit in the front? 20mm looks great in the back but want a little less for the front.
With the lack of pictures on the forums from angles that would've helped me make a decision, I went with the fact that I knew 3/16" wasn't going to make much of a difference. From there, I waited for spacers to go up for sale used and bought what was available. In my case, I bought 20mm for the front and rear for the same price that I would've paid for a single set at retail.
Reviving this. Curious what the consensus is for spacers on a lowered MYP on Ubertines. 20mm back/18mm front for a flush look?
I'm not sure if you mean a MYP that's lowered with aftermarket springs/coilovers or the fact that a MYP is lower from the factory. Either way, you can see pics of my 20mm front and rear on my lowered LR, which is slightly lower than a factory MYP. The angles of the pictures I took were what I was hoping to find on the forums when I was making a decision. It looks perfect to me in person when I'm walking up to it or I see it roll by when my wife is driving it. I wouldn't overthink the 1/16" difference for the front, especially if you're able to find a used 20mm set on the forums.
I agree I think this setup is exactly what I want. Its so hard to get a good angle of pictures and this is perfect. Its exactly what Ive been wanting. I had no idea how aggressive I need to go with spacers and NOBODY has recommended 20mm all the way around. This is exactly what I want THANK YOU! I have an MYP but I have those wheels so Im thinking it should look pretty much the same. I hope
Reactions: Simans82
What’s your setup? All specs please.
This is the EXACT look I’m going for! This is super clean!
Here are the final offsets when taking the spacers into consideration.
