Took delivery of Y LR one week ago. Using mobile charger for newly built & wired (June 2020) structure with NEMA adapter 14-50, installed by licensed electrician. Don't know which brand of receptacle he used. The first day it charged successfully, from ~70% to target 90%. Failed thereafter. Mobile charger is showing green lights "All on" and red light "5 flashes" which indicates an adapter fault. I've unplugged/replugged several times and the connection doesn't seem to be the problem. Successfully, if slowly, charging with 110V/15A through standard receptacle. Ideas/suggestions? Thank you.
