I am about to install the rear camera and would like to know if anyone attached the camera to the plastic siding instead of the rear window. If yes, are you happy with the decision and is it holding fine on this surface. I am a little concerned of sticking the camera on the wire heater pellicle (potentially damaging the pellicle if/when removing the camera). I may also be purchasing a Rear Liftgate Sunshade and was wondering if the image quality of the camera installed on the plastic siding is greatly affected by the Sunshade.
Why would you not put it directly on the glass? That's what I plan to do with the rear camera when I install my 900, and I'm pretty sure what most people do. You're right that putting it on the wire is a bad idea.
I followed the norm and had my rear camera attached to the window. Only real issue I have experienced is that the tint on the Model X rear window darkens the picture for the rear camera making for poor quality. Not sure there is a fix for that since the tint is in the glass. Would be great to capture the picture from the vehicles rear camera, it provides a much better view.
Interesting......I did not know that such an adjustment exists, but will pull out by owners manual and look into it. Thanks!!
I attached my rear camera to the plastic trim rather than the window and it has held on fine for three years. I did that due to a) the defrost wires and b)visibility (you can't see the camera while driving) and c) I didn't want to stick it to the tint layer on the rear window. I have since removed and reapplied my front camera and using dental floss to cut the adhesive, it was not a problem to remove the camera from a tinted window.
Many thanks for sharing your experience. I will follow your advice and attach the camera to the plastic trim.
