I am currently waiting on my Model LR AWD configured on 06/28/2016. No VIN assigned yet.
I would like to get started on process for getting my garage ready for charging the Model 3.
I live in a 3 level single family house with an unfinished basement. The 200 amps main panel is located in the basement on the other end of the house from the garage.
Below are the options I am thinking of
1. Install NEMA 14-50 : Ths will allow me to charge Model 3 upto a max of 32A. This can be done by Installing a 40A breaker in the main panel and running approximately 50ft of #6/3 Romex wire to the 14-50 outlet in garage.
2. Wall Connector Install : Will need to wire for at least 60 Amps so that I can charge the model 3 at a max of 48 Amps. I am not sure if this will require a separate sub-panel to be installed or if it can be wired to 60Amps breaker in the main panel.
I input all the existing electrical appliances information on this website and the load was calculated as
Will going with Option 2 require a sub-panel or can I install a 60 Amp breaker in the main panel?
- Watts:26,063
- Amps:108.59
