Need help on a question on fitting 2 bikes in the Model Y
Wonderful! Any tips on getting the ebikes in and out? They are heavy and over 70 plus lbs.
I have a couple of Lectric Bikes that are about 67lbs each. I have a "Hollywood rack" for fat tire bikes that also weighs about 45 lbs.
just a few pointers,
1. If you can remove the battery of your bikes before loading them, it will reduce the total weight burden on the hitch. I also remove the seats/seatpost since I have a quick release on them,
2. to load a heavy bike, I just lift one side at a time, I normally line it up next to the rack first. then apply rear tire brake while lifting the front wheel (kind of like doing a wheelie) while diagonally putting it on the bike carrier.
3. next you have to lift the rear end of the bike and place on the carrier. but this time it will be easier because the weight is significantly reduced since half of the weight is on the rack already.
Reactions: mazers
My Modified Lectric Ebike on a Kuat Transfer V2 attached to 2019 Kona EV.
