How old is your 12V battery? Did you noticed any warning? Did you use the
Service Mode to check for any messages?
I would recommend to install a
Bluetooth 12V Battery Monitor, so you ill be able to check, when you car is sleeping,
how often the 12V battery get recharged by the DC/DC inverter.
Typically the 12V battery get recharged after about three days, if the car has been sleeping during that time.
However, if you noticed that the battery get recharged almost every 24 hours for about one hour,
this will indicate that the 12V battery cannot keep its charge and need to be replace.
In this case, I would recommend not running any update until you get a new 12V battery.
You should carry a small 9V battery, in case you could not open your door.
This will alllo you to open the frunk.
Note: I have this bad experience of not been able to open my the door, because of a bad 12V battery.
But with the phone App, using the Climat menu, I was able to crack the window and pass a stick to press on the inside dooe button.
