New Model X Owner UK - Salvage Repair
Hi Guys,
I've recently purchase a Tesla Model X 2018 Category S Damaged.
I sold my Dodge Challenger SRT and this Tesla came up and took my fancy, I know its going to be a long road to repair!
I've replaced the following parts with genuine Tesla Items. I've had the car a week and its now structurally ok.
External
- Bonnet
- Front Headlight
- Wing
- Drivers Door
- Inner Wing Repair
- Front Bumper
- Front Bumper Wirining Harness
- Lower Wishbone
- Driveshaft Offside
- Steering Rack Tie Rod
- Lower Nuckle
- Anti Roll Bar
- Lower Arm
- Hub Assembly
- 20" Allow Wheel & Tyre
- Headlight Support Bracket
I do still need a new sway bar for drivers side!
Internal
- Full Airbag Replacement
- Air Bag Control Unit
- Seat Stitching Repairs
I have replaced the SRS Module and all of the internal cabin air bags, the seats are currently being repaired by a trimmer so I cant check the status of them yet.
These below messages are when I try to put the car into drive;
BMS_f062_sw_ctr_pwr - Service Required
BMS_f033_sw - Service required
DI_014 - Unable to drive voltage supply to low
GTW_w018 Power Reduced - Vehicle Systems Shutting Down
Battery is showing 86 miles on both the dash and the steering console that's was 92 when I collected the car. I haven't changed / checked the main battery pack pyro fuse under the car yet as I don't have the star key.
I also have the below service messages when the car is idle and on 12v booster pack power.
GTW_w182 - Park Assist unavailable
GTW_w105 - Safety Restrain System Fault
MCU_w008 - TPMS - Tyre Pressure Very Low
ESP_w003 - Traction control disabled
ESP_w003 - Stability control disable
TAS_a218 - Air Suspension adjustment unavailable (Suspension may not be level)
I currently have the following items disconnected;
All Seats are out
Airbag Module is In but I don't believe this has been reprogrammed, I have sent mine away to be done.
Front Drivers Wheel is off awaiting new tyre
Front bumper is off, loom is connected but missing 1 sensor on the end of the loom
