I am also reading that there are different types of adapters i.e. CHAdeMO, CCS/SAE adapters. Can i use any of these to charge my Tesla?
Thanks, I am getting a quote from him. Our FM informed us that they will have a Chargepoint Charger up and ready within 2 to 3 weeks. The cost is 50cents and hour and it will be 6.6Kw.
They also said that it will l use a J-1772 connector.. Can i charge the model 3 with it? If yes then, how much range can i expect to add in 1 hour of charging in summer and how much range can i expect to add in 1 hour of charging in peak winter?
IMHO, you will be much happier with a 14-50 of your own than a 6.6kwh public connector at 0.50/h. I don't have the recharge rate for 6.6kwh but I am almost certain it's slower than a 14-50.
Another dumb question. How do you actually charge the car? I mean the electrician will install the 14-50 receptacle on the wall.
Does tesla supply the wire that connects to the car and the adapter plugs in the receptacle? or do i have to buy the wire with the 14-50 plug. If that is the case then what does the other end of the wire look like?
How does this work if i happen to find a 120V plug? or J-17772 or CHAdeMO
Sorry for asking so many questions, just trying to understand this.
Thanks, regarding the enrgy calculation, am i dong this correctly?
Off peak rates of our hydro utility is 6.7c/kwh and mid peak is 9.6c/kwh. If i am charging at 6.6Kwh ( i know i will be doing at 7.7 but lets assume 6.6 for cost comparison) then my cost to charge at home for an hour is around 43cents and mid peak is 51cents.
So not much of a difference and i should probably plug it in during winter months to get over range anxiety.
So i guess i can continue to charge at 80% in Winters or drive with heating set at 22C and drive at 140kmph without any range anxiety when its -40 outside.
So off peak rates of our hydro utility is 6.7c/kwh and mid peak is 9.6c/kwh. If i am charging at 6.6Kwh ( i know i will be doing at 7.7 but lets assume 6.6 for cost comparison) then my cost to charge at home for an hour is around 43cents and mid peak is 51cents.
So not much of a difference. I will probably charge faster at home.
Are my calculations wrong?
FM is facilities management. Its a public charger but you have to pay for parking to get into the garage. I am hoping to snag a 120V plug somewhere..
Yes, i think the cost will be a wash. I am in Ontario so all the fees apply to me. Also, I have to pay for parking anyway and am paying for it now, so there is no extra cost. Once concern i have is that, there was a tweet from Elon Musk which said:
Model 3 drive unit & body is designed like a commercial truck for a million mile life. Current battery modules should last 300k to 500k miles (1500 cycles). Replacing modules (not pack) will only cost $5k to $7k.
Given this fact, if i charge the vehicle once a day from say 15% to 80%, for 300 days a year then is the batter pack designed to last only 1500/300=5 years?
If that is the case then should i aviold charging twice a day and charge only at work and/or home and only charge twice a day when i really need it (peak winter when its v cold outside).
Thanks,
