Simon,I'm struggling here with US/UK terminology differences. Rotors I can translate to discs.
What are the aluminium hats please? Where are they fitted?
Finally, is there a specific type of pad material needed or do people use the Tesla standard? If different, does anyone know if they're available in Europe?
Thank you very much.Simon,
We are making 2 piece rotors that have an Aluminum center section(hat) that connects the hub of the car with the cast iron, nitride treated friction disc the brake pads clamp. This is a standard may to make high end brake rotor, saves weight and for our application saves cost for the nitride treatment since the hat portion does not need to be treated. Lower weight means it takes less energy to accelerate or decelerate the car.
The rotor will work with all brake pad materials, we are offering 2 Carbotech friction material options for brake pads that have proven to work well with the nitride coating since they have good initial bite and drivers have found them to create confidence for Roadster drivers who are using the Cedar Ridge Fabrication Tesla rotors.
