Just installed mine today and this is how I wired mine up. Hope this wiring diagram helps. Thank you guys for the info. Sounds great yet still tuning the sound.
My passenger side kit did not include vehicle-specific instructions and the YT video wasn't exactly detailed step by step but I managed for a first-timer. NVX did not respond to any emails for product information or installation instructions.
Some questions:
- For XLCA2 TURN ON MODE: REM, are we supposed to splice into the same 12+ power wire from the amp for the REM IN for the LOC to automatically turn on/off?
- For TURN ON MODE: AUD, do we just let it be and it'll automatically turn on when audio is detected?
- I left mine at MODE: DC and it seems to turn on/off by itself. Not sure if I'm doing it correctly.
- I'm using the knob that came with the amp. What's the knob included with the LOC for and is it needed?
- I saw the OP is using both side NVX subs. Can we simply add the other side sub using the extra outputs on the VADM1? I'm currently only using one of the output pairs going to the sub.
It's definitely thumping. Still playing with the adjustments. I like rolling bass (like feeling the bass guitar and not just the kick drums) and turning the LPF a bit helps with that. Installation took me about 5 hours as well. If I had the wiring diagram above it would have saved so much time. For the ground I used an existing grounding bolt next to the stock amp. The included cable had just enough reach for the NVX amp to be mounted as seen in the YT video (bottom left of upper trunk area).
