s1rk
Opening the charge port and unlocking the charge port are two different things.
^ What he said. U can open the port door, but the charging port itself has another actual lock which u can disengage when you have a charging cable attached to the car. An example of unlocking the port is when you are using a supercharger cable with a broken unlock button. You can still use the charger but you will have to use your phone app to unlock the actual charging port to release the charging cable.
Speaking of charge ports, mine just failed on me last night. The charge port opens, but the locking mechanism inside the port is stuck in the locked position which means I can't insert the charging cable. I kept hearing a machine "whirring" sound as if it's trying to bring the lock down but to no avail. Has this happened to anyone? I have an appointment with them today after arguing over the phone since the lady wanted to originally schedule me for the 28th.... I'm guessing it will have to stay with the service until they order the part. If that's the case, I'd rather keep the car and just manually unlock the port to charge my car at home.
