Hopefully it is still available on the CAN bus. Definitely not going to update now.So does this also break the power tools for tesla app?
It is still available on the canbus.
Even using launch mode, the max power on my p90dl is about 1% lower than before mostly due to lower max current..
This is with the latest release. My max current used to be about 1620 amps without launch mode. Now it's down to about 1605 using launch mode. Normal aging would increase the battery's internal resistance and lower max power, not max current. Current is programmed via software.
July, 2016 P90DL with battery version 1088792-00-A.
I'm hesitant to add my data since I don't use power tools and am not sure how they determine max power.
Battery voltage and current are available, so you can multiply them to get kw.
Max Power for a 0 to 60 run using launch mode:Let me know what voltage, amp and kW numbers you get.
1606 amps
313.05 volts
502.8 KW
This max power occurred at 46.4 mph.
I used to get a max of about 509-510 KW
Tell them to prove it by showing you the "vehicle log data" that they refer to.Ugh. Response from my SA:
The data that customer is using is not supported by Tesla and may not be relevant. Customer cannot rely on that data. There was no FW changes that would reduce power. The vehicle log data shows no power output difference between 12/21 and 3/6. Dyno data would have showed no power changes.
I interpreted their statement as discounting your log data, and saying that their log data didn't show a power difference. For instance because it was finer resolution and showed a power peak that your missed (possible?)It's nuts because I'm the one that sent them the data and a graph showing the difference. I could do statistics on it, if they want and prove the difference....
