My front passenger window has been "rough" going up since I first received my car. I thought it might be lack of grease on the slides for the window. I had the need to fix my passenger door handle today ( white wire broken on the moment switch to open the door from the outside) while starting to replace it I noticed the cable for the window was not in the plastic roller but grinding it's way into the aluminum pin holding the roller. It was clear to see through the door handle opening. So 5hrs later and I almost have it back in place ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
