Co2 refrigerant systems seemed to get a lot of publicity a couple of years ago, but apart from large commercial systems, I haven't seen anything sized for a typical home. Is anyone making home sized systems yet?
A lot of people buy for "cool" factor or because they're misled about incremental savings vs air source, but in our climate I don't see GSHP justifying under 4000 sf. When the tax credits go away I can't imagine what will happen to that industry.
Nice. That's not far off what wimpy grid tie setups on 'green' homes run in a lifetime. I don't understand why more people don't shoot for a brute force method. I suppose it's kinda mandatory if you want to off grid charge a pair of electric cars, but it sure works.
Do you have any datalogging on your battery SOC over time? I'd be interested to see something like a SOC graph over a week or so period. Did you do any low SOC testing, loading your little grid down hard at say 20% SOC? What kind of sag do you get, and how do the inverters handle it? If you have incandescent lighting somewhere, can you notice dimming while switching on an inductive load, some kind of large motor?
how is work comming along on your "dump loads"? once you nearly double the number of panels (with the groundmount panels), and the fact that peak production season is comming soon, you'll probably run into the battery full situation, and need to dump the excess energy...
I'm logging everything at 5 second intervals.
Currently don't really have a lot to go on, but I'll post some graphs and such later on.
I did two tests so far where I ran the pack down to about 15% SoC. The AC output voltage on my inverters starts to suffer a bit once the pack gets below about 42V. Still fully usable, though. At 15% SoC the AC output voltage was down to about 215VAC. Low, but fine for normal loads. DC voltage sag is pretty nonexistent. Literally just over 1V of sag at 55kW AC side load. I over sized my wiring and bus bars to minimize DC side losses.
The inverters work pretty well with all loads I have. The one exception is my one aging heat pump/AC unit. When it kicks on the surge briefly loads the inverters to the point where a bunch more will come out of power save mode to compensate, then settle once it's running. They handle it, although a hair less smoothly than the grid would. Honestly, to me this just points out a problem (the AC unit) that I probably wouldn't have noticed otherwise.
I actually started some scripting for the HVAC (Nests) to adjust the inside temperature in response to the pack approaching full. Also, dump loads aren't *required* for my setup, but they'll be nice. If the panels are making more power than I'm using and the pack is full it just doesn't use all available power from the panels (wastes it). Somewhat unfortunate, but, such is life trying to be off-grid year round. No way I'll be able to use *all* excess power I make in the summer. Not without having somewhere to store it in another form, long term, even at low efficiency.
You could dump the excess to a hot water tank or an ac unit. It's just a matter of hooking up the controls. They make a desiccant dehumidifier too that has been used for dump loads on solar hot water systems.
I have no idea on the technical feasibility of this, given that you're off-grid, but is there a way you can switch to selling your excess capacity to the grid when your pack is full and you have nothing else to do with the excess power? Might as well get something for it rather than letting it go to waste.
If you really want to dump juice, get a rack of old SHA256 miners.
That's interesting the AC voltage drops that significantly with a low input. I wouldn't expect that kind of behavior and for it to still allow for high loading without fault. So, the input voltage range of the inverters is more problematic than the internal resistance of the pack at low SOC's? I suppose you're running something near 1/4C at a 55kW discharge, so I shouldn't be so worried. Is that rack two full 85 packs, or is it the full proposed 191? Whats the deal with the 191 anyways? Did you ever measure the drop across your wiring and connections on the DC side? Since you're vaguely closer to utility scale here, its interesting to see what losses you get with practical oversizing of the conductors. I'm just wondering how much the juice is worth the squeeze.
Did you ever mess around with varying your output voltage? Obviously theres a lot of different interactions there, but I notice some loads are perfectly happy to draw a little less on a little less voltage. Although some things draw more and it could end up being a wash, and some things will have reduced performance so its kinda equipment dependent. Presumably you're shooting for 240VAC? It's possible the inverters handle hard loads better at a lower or higher voltage as well. Typical A/C units run the scum class of motors, PSC. Technically, with a PSC motor, you know its working if you get a huge current spike on startup. A hard start kit is designed to increase this current spike so the motor starts up faster, minimizing the appearance of lights dimming, and giving the compressor more oomph to overcome higher head pressure from short cycling or unbalanced conditions. I'm not so sure this works off grid when your inverters are effectively generating the power after its needed. They don't know this 200A load is online until the voltage tanks, and they're left reacting. Higher quality inverters deal with this fairly well, but a big motor starting up direct on line, is about as tough as it gets. You can reduce it, with a soft starter, smaller compressors staged, or drink the juice and run BLDC. My inverter mini split is only a 3/4 ton, but it fires up with so much damn grace. No noise, thud, sag, shake, dimming... I almost feel sorry for the grid when my other conventional A/C unit fires up, but all the lights are LED so I don't notice the little blip. My TED sometimes does, though.
Do you plan on keeping a grid connection long term? The obvious choice would be to dump excess on grid. I see grid tie inverters that are too big for residential use go cheap all the time. But you're going to need to dump a lot of juice to overcome that $18 meter charge or whatever it is.
7kW is just under 2 tons, or 24,000 BTU. That's big for a mini split, but I don't think you really need a unit big enough to handle that 24/7 since the load should only persist a few hours I'd imagine. You just need enough thermal mass to allow the unit to run flat out, minimizing temp rise, until the load goes away. A 1 ton mini split should be fine, since MOST of the time it will likely be overkill.
The Fujitsu 12rls3h would probably be the one. They make the same series in a 9, 12, and 15K BTU. The 12 is rated 0.79kW full load, cooling. You can get 2 and even 3 ton mini splits, but the efficiency drops way down, costs go up. Fill the room with bricks or water or something to soak up the spikes, I'd imagine a 1 ton unit would be fine.
WY Net Metering law leaves the monthly 'equipment charge' intact (untouchable) come end-of-year accounting. Does PA operate differently?
Also WY law prohibits home owners, ranchers, businesses from selling electric power to 3rd parties.
