It’s inside under stairs.Is your electric meter outside in a white cupboard thing like the one shown open in the picture? You just need to show a picture ideally with that and where you want your podpoint installing in the same picture or via multiple if not possible.
If this is anywhere near the wall in which your hoping to install your podpoint take the necessary pictures. If is your fuse board any better positioned?It’s inside under stairs.
They will supply and fit the cable, but they need to check that there are no issues with where you want it to go. They want to see the proposed route of the cable.Example. Are they saying I would need a cable already run from meter to desired location? Or do they fit the cable from meter to desired location.
Is that earth actually connected to anything?
Thanks it was confusing felt like I had to do the pre workThey will supply and fit the cable, but they need to check that there are no issues with where you want it to go. They want to see the proposed route of the cable.
I took a photo of the front of my house and the side where I wanted the charger to be placed. I asked if I could run the cable under the floor rather than outside and they were happy for me to do that. They sent the cable prior to the job and I ran it before the installer arrived. Otherwise they would have just run it out side.
Nope, seems that it was cut off but not sure why. Is this going to be issue?Is that earth actually connected to anything?
Nope,, they just want to check there is nothing non-standard in the routeThanks it was confusing felt like I had to do the pre work
don't EVER touch the radiatorsNope, seems that it was cut off but not sure why. Is this going to be issue?
Agreed. Looks like the ground for the radiators has broken.don't EVER touch the radiators
Only if you want to liveNope, seems that it was cut off but not sure why. Is this going to be issue?
