I’ve never heard this before, and have to disagree. After dozens of tire repairs at many tire shops, I know of none that plugs a tire, from in or outside. The gold standard repair is a patch, not a plug, installed from the inside. The outside plug is supposed to be a temporary solution to get you to the tire shop for the patch repair. In most cases however the plug lasts the life of the tire without further remediation. I’ve also never heard of a tire shop removing a plug. Again, they apply the internal patch and that’s it. All this is assuming the hole happened in a repairable part of the tread to begin with. If not, no reputable tire shop will apply any repair but suggest a new tire instead.
Stop being ridiculous by arguing the semantics of the word "plug." If we are going to argue semantics, you are 100% wrong to call it a patch. No reputable tire shop is going to use just a patch to fix a hole in the tire. They are going to use a patch / plug combination. For the rest of it, please do you research before commenting.
