http://www.rogueengineering.com/rogue/BRK/BRE-STICK.html
Also check out this thread on powder coating the calibers it looks great
http://www.teslamotorsclub.com/show...g-of-brake-calipers-good-riddance-to-G2/page2
I think you are OK, you don't have to change the seals until he temperatures goes over 464 degrees Fahreinheit
Brake Check!
The secret is OUT! Brembo Motorsport has been using these little goodies for years. Now you can use the tools that Brembo Motorsport uses for their sponsored teams!
Why Monitor Brake Caliper Temps?
By monitoring brake caliper temperatures, you can make sure that the working range of the brake fluid has not been exceeded. If the temperatures exceed the fluid, fluid vaporization can occur causing loss of the brake pedal.
Temperature Warnings
For those running fixed, multi-piston calipers (Brembo GT, for example), recommended working temperature is < 200°C (392F), whereas the maximum acceptable working temperature is 220°C (428F);
Over 240°C (464F), the seals fitted into the calipers can be overheated and they will not guarantee the right performances of the caliper (sealing, roll back, fluid absorption,…);
If the caliper temperature goes over 240°C (464F), the dust seals and pressure seals should be refreshed.
Sold as a
pair, sent via USPS in an envelope (no tracking or insurance available, unless ordered with other merchandise).
