JPP
I think there are two "ramps" that could be confusing.
If the grid disconnects while the Powerwall is fully or close to fully charged then it will set the frequency to the max instantly. No "ramp". I'm not sure I understand the behavior @aesculus mentioned.
If the grid disconnects while the Powerwall has the ability to charge then the frequency will stay below the max and slowly increase to max as the Powerwall charges. Once the frequency is too high for the PV then solar production will stop, the Powerwall will start to drain and the frequency will start to decrease back towards 60hz. This is a "ramp".
Makes sense--but still an issue. Do the inverters 'understand' the ramp and keep operating if the PWs can 'absorb' the power? Are the inverters supposed to support some kind of 'ramp down'? I thought the inverters just understood 'on' or 'off'.
