The problem seems unique, as I searched around but couldn't find any discussion.
Car is 2019 Model 3 mid-range plus. I have been using home outlet (117v/12A) to charge (which is sufficient as the daily usage is only 10-12 miles).
If the car has finished charging (or is woken up from sleeping mode), the charger can't be unplugged. I have been following different suggestions that I could find online, but the answer is always no. The only way to get the charger out is to use manual release from the trunk.
If the car is still charging, I can use the buttons of "stop charging" and "unlock charge port" (app or in-car screen). Then the charger can be pulled out easily.
This problem started roughly half a hour ago (I don't recall the software version).
Does anyone have any clue what could be wrong and whether there is an easy fix?
When I contacted Tesla mobile service, they simply suggested (online) to replace the whole hardware and re-build (their quote was $700+).
