Hi guys.
Had an issues with my 2.5 roadster I hope some of you can clearify.
The car had been parked outside over night while it was snowing, the driver side door opened ok (had to pull a bit harder, but no problem), but the trunk did not open, due to ice.
After driving home I had my car in a heated garage over night. The next day the driver side door did not open (no "motor sound" when pressing the button), but the passenger side door worked. The trunk button was also still dead.
I did not have much time to look at this, since I was off for work travel. But when I returned back home four days later the status was the same.
Anyway after opening the trunk manually with the key, the driver side door started working again (as well as the trunk).
So I am just curious, does the driver door and trunk have some kind of common circuit or was it just coincident?
