this morning I managed to squeeze in a quick freeway test before heading to work. It was five miles each direction on the same road, the road is flat and straight but has a slight grade to it resulting in a solid 350 wh/mi one direction and 290 wh/mi the other. That’s 320 average going 75mph at 37 degrees with the heater at 66 / fan level 1. Also the car was fully warmed up at that point.
I think those numbers are pretty high if accurate. Certainly higher than our 3 SR+ in the same conditions. But my guess is the Y is just not as aerodynamic and it is prob heavier. Still kind of disappointing but it is a mini SUV... so... /shrug
I also wanted to add: there is certainly no shortage of complaints about the size / visibility of the rear window in the Y. That is something that concerned me going into this purchase. However - unexpectedly I feel more comfortable with the Y when checking blind spots than I do the 3. My wife swears she never had any issues with her 3 but I always felt limited on the passenger side. While the rear window on the Y is “small”, I feel like the driver position is high enough to see clearly over the passenger rear door for cars in your blind spot... and for me that makes the direct rear visibility far less of an issue.
