ALASKA: The maximum speed while towing a mobile home is 45 mph.
ARIZONA: Vehicles towing trailers or semitrailers may not exceed a rate of speed that causes lateral sway.
ARKANSAS: Speed limits are 70 mph on rural interstates; 55 mph on urban freeways; or as posted.
45 mph is maximum when towing house trailer.
CALIFORNIA: Maximum speed for any vehicle towing another vehicle is 55 mph.
DELAWARE: No trailer carrying a gross weight of load in combination with a vehicle in excess of 4,000 lbs. shall be operated at a speed over 10 mph unless equipped with suitable brakes controlled by the operator of the towing vehicle.
FLORIDA: Unless otherwise posted, 30 mph in business and residential districts, and 55 mph at any time at all other locations. Turnpike and other designated highways 65 mph, except where posted 70 mph (minimum speed 50 mph).
KANSAS: Every combination of vehicles shall have a service braking system, which will stop such combination within 40 feet from an initial speed of 20 mph on a level, dry, smooth, hard surface, and shall have a parking brake system adequate to hold such combination on any grade on which it is operated under all conditions of loading.
No person shall operate a vehicle towing a house trailer at a speed greater than 55 mph.
MICHIGAN: A person driving a passenger vehicle pulling another vehicle or trailer shall not exceed the posted speed limit.
MISSISSIPI: Every trailer which shall be towed on public highways at a speed greater than 20 mph shall be coupled to the towing vehicle by means of a safety chain, chains, cables, or equivalent devices in addition to the regular trailer hitch or coupling.
No more slack shall be left in any safety chains, cables, or equivalent devices than shall be necessary to permit proper turning. The safety chains, cables, or equivalent devices shall be so connected to the towed and towing vehicles and to the drawbar to prevent the drawbar from dropping to the ground if the drawbar fails and shall be of sufficient strength to control the trailer in the event of failure of the regular trailer hitch or coupling.
NEBRASKA: No person shall operate any motor vehicle when towing a mobile home at a rate of speed in excess of 50 mph.
NEW HAMPSHIRE: ...Every combination of motor vehicle with a trailer or semitrailer when driven upon the roadways of the state shall at a speed of 20 mph be capable, at all times and under all conditions, of stopping on a dry, smooth, approximately level pavement free from loose material, upon application of the foot or service brake, within a distance of 30 feet.
NORTH DAKOTA: Every trailer operated at a speed in excess of 25 mph must have safety chains or brakes adequate to control the movement of and to stop and to hold such vehicle. The safety chains or brakes must be designed so that they can be applied by the driver of the towing vehicle from its cab, and must be designed and connected so that in case of an accidental breakaway the brakes are automatically applied.
OHIO: 55 mph is the maximum speed for any vehicle or vehicle combination that weighs over 8,000 lbs.
OREGON: Adequate to control trailer under all conditions of varying speeds and weights; 1 safety chain is required on all trailers with 2 connections to the towing vehicle. The tensile strength of the safety chain must equal the gross weight of the trailer.
SOUTH CAROLINA: Manufactured, modular, or mobile homes must not be transported at a speed in excess of 10 miles below the maximum posted speed limit when the maximum posted speed limit is in excess of 45 mph, and never in excess of 55 mph.
A person driving a vehicle towing a house trailer must not drive faster than 45 mph.
SOUTH DAKOTA: In addition to the regular trailer hitch or coupling device, every trailer that is towed on the public highways at a speed of more than 20 mph must be coupled to the towing vehicle with a safety chain, chains, cables, or an equivalent device. This requirement does not apply to a semitrailer having a connecting device composed of a 5th wheel and kingpin assembly that meets the requirements of the Interstate Commerce Commission.
TEXAS: A trailer or pole trailer is required to have brakes if its gross weight exceeds 4,500 lbs. A trailer with a gross weight between 4,500 lbs. and 15,000 lbs. is not required to have brakes if it is towed at a speed of not more than 30 mph.
UTAH: Every motor vehicle and every combination of vehicle shall have a service braking system which will stop the vehicle or combination within 40 feet from an initial speed of 20 mph on level, dry, smooth, hard surface.
Every motor vehicle and combination of vehicles shall have a parking brake system adequate to hold the vehicle or combination of any grade on which it is operated under all conditions of loading on a surface free from snow, ice, or loose material.
WEST VIRGINIA: ...A motor vehicle or combination of motor-drawn vehicles must be capable of stopping at the following rates as if on a dry, smooth, level free road: (1) vehicles or combinations of vehicles with brakes on all wheels must be able to decelerate at a speed of 14 feet per second; and (2) vehicles or combinations of vehicles not having brakes on all wheels must be able to decelerate at a speed 10.7 feet per second.
WYOMING: Every combination of vehicles must have a service braking system that will stop the combination of vehicles within 40 feet from an initial speed of 20 mph on a level, dry, smooth, hard surface.
Every combination of vehicles must have a parking brake system adequate to hold the combination of vehicles on any grade on which it is operated under all conditions of loading on a surface free from snow, ice, or loose material.
PUERTO RICO: Same as for passenger cars according to the zone, but maximum speed for heavy motor vehicles is 10 mph less than permitted in any zone.
