As long as it isn't inconvenient for you and you don't mind fiddling with it, there's really no downside, I don't think. As @KenC says, feel free to change it up, see what happens.
At the moment, neither charging earlier or delayed charges would cause me any inconvenience whatsoever. I can easily adopt either approach. If one is going to show better results in more accurate estimates (and by chance result in slight increased range back), then i'm happy to continue those habits?
I would just caution that if you actually want to see what happens, you should not update your software for the duration of your experiment. There is a fair amount of circumstantial evidence that software updates can sometimes impact BMS estimate algorithms (though sometimes it may just be a coincidence).
Unfortunately, I've not keep the software versions consistent during the tests. It simply takes me a good week or more to do a single cycle i.e. 90% down to a lower soc. So only managed perhaps a cycle or two before updates appear. Will bare this in mind thou.
Also note that if it gets colder during your experiment, and your car is not garaged in a warm location, that's also going to throw off your results (BMS estimates go down when the battery is cold, because there is actually less energy available from a cold battery).
Yes agree, its not ideal as Summer is over and into Fall....so temps are declining now.
We are located in Scotland, so not exactly associated with warm and sunny weather climates.
Still double digit temps in the region of 14-11C. The car is garaged around temps of 14C or higher.
I assume before charging, it would help if the car battery is warmed up i.e. turning on HVAC for a period (30mins?) That would help with estimates, and is better for the battery when charging whilst it up to temp?
This in comparison to charging from cold. Would there be any sense in doing this?
As i have heard that turning HVAC on for short period (20-30min) before going out on a journey is good practice especially in colder climates assuming that the car is plugged in ofcourse.
