Re-gearing? trade top speed for acceleration
Discussion in 'Roadster: Performance' started by rgjones, Aug 30, 2013.
  1. rgjones
    rgjones Member
    San Diego
    Would like to start a discussion about the feasibility and possible trade offs if we were to change the gearing (final drive) on the Roadster.
    I still love my 2010 2.0 Sport but am ready for more acceleration!
    As it is I have my Tattler set to automatically select Performance mode when driving - never know when you might 'need it :)
    Most of the performance cars in my neighborhood slink off now, but saw an Aventador the other day! - Could be a challenge if he has time to engage launch control.
    So far it does not look like a lighter, lower (CofG) battery pack is going to happen soon (wish - acceleration & better handling),
    so it seems the simplest way to accelerate faster is to re-gear the car, trading off top speed.
    I'm ready to take top speed down from 125 to say 95.
    What would that do to the acceleration?
    Other factors to consider? WHr/mile changes at low load steady speeds? (70, 50)
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I did a charity drag race event recently. An Aventador took the top spot with a 1/4 mile time of 10.39. Both the Roadster and the Model S are in the 12 second range. Somehow I think it would be hard to catch him even without launch mode!
    Changing gearing like that might improve torque by as much as 30%. That certainly could make a significant difference. But I wonder if the firmware would freak out if you changed the ratio.
  3. hcsharp
    hcsharp Active Member
    Vermont
    While you're at it, if we can change to a limited slip differential I would like that. A ltd slip diff would reduce range slightly and increase understeer but would provide some benefits. I don't think re-gearing would change power consumption but not sure. It would make regen stronger. It would affect the computer in several ways. Right now there are some correlations between speed and motor RPM that would get screwed up. It might cause the motor and PEM to generate more heat at highway speeds. I'm sure many of us would love to see you do it so we could see what happens!:tongue:
  4. ToddRLockwood
    ToddRLockwood Active Member
    Burlington, Vermont
    I wonder if you might pick up some gearbox noise, as the original ratios might have been carefully chosen to cancel noise—as was done on the Segway.
  5. vfx
    vfx Well-Known Member
    CA CA
    I thought Joost and his team has done this. (or know someone who has).
  6. rgjones
    rgjones Member
    San Diego
    oo, do tell please!
  7. jeremyz
    jeremyz Member
  8. omgwtfbyobbq
    omgwtfbyobbq Active Member
    Southern California
    If you're interested, I have an octave script hanging around to accurately calculate acceleration. I think you could tweak it a bit to compensate for wheels slip, and have a good idea what changes in gearing will do to acceleration from 0 to whatever.
  9. Smop
    Smop Banned
    This has been done but heat was a problem (which was kinda solved).
  10. qwk
    qwk Model S P2681
    Do you have anymore details?Please do tell.
