I had a really annoying metal sound squeak coming from the second row seats. At first I thought it was from the hinge assembly, because it only squeaks when the rear seat is folded down.
Rather than taking it to service, I decided to look for the issue myself, maybe even fix it if it's a loose bolt or something easy.
Took apart the bench, which was really easy, and apart from finding lots of tags and unclipped wires, nothing apparent.
So I went for the seat back, which was also easy to take off (just grab and carefully pull up). Took all of a few seconds to take off.
And there it was. A loose bolt. Which, when tightened, along with its sibling on the other side, holds a metal U-shaped frame onto some metal seat pegs of some sort. When loose, allows the frame to slide up and down (bare metal on bare metal) on the steel pegs, making a horrendous squeak. I suspect many will have this problem especially since it seems so easy to loosen by itself.
Hoping this will help other people who come across the metal-on-metal squeak in the back seat, who might also think the problem is coming from the folding pivot mechanism (its not!).
