I would certainly put the '
Speed Limit Mode' to the minimun of 50 mph and '
Creep Mode' on.
However, I think that the 'Speed Limit' only emit a warning while driving, but still allow you to drive above the selected speed?
Under 'Safety & Security' you can turn off '
Allow Mobile Access', so this is blocking the App to access the car remotely,
this is
certainly something that I would not to be disabled, in particular because you cannot access the
location.
Remember that the frunk cannot be opened in valet mode, which will be an issue e.g. if you get the car wrapped.
If you are sure that access to the frunk isn't required, I think the main benefit is that
they can't screw around with things like your registered keys and driver profiles, or pair Bluetooth devices.
Note: Under 'Profile' you can create a new user, would it be possible to select then this new user and locking this user
with a PIN number so this user would not be able to make any changes but still able to open the Frunk?
