Apologies if I'm missing an obvious thread that might help with this, but need some advice from those in the know on this please.
Long story short is this - debris in the passenger side outer tail/brake light (UK car) - this is the charge port side of the car (2017 model S).
Tesla's response is that they don't clean or service light units - cut and shut job, either stump up the cash for a new one and fitting or live with it (£500+ minimum) - so I'm very tempted to get something in the back if I can and give it a clean out to get a 90% job done. Won't be perfect, but hoping it will be much better, and not needlessly costly.
To get a long hose of some sort attached to a vacuum into the back of one of the drain / air holes in the back of the light fitting, I'll obviously need to remove it, which means unplugging the inbound charge cable from the back of the fitting. With the 12v battery and the 'fireman's loop' disconnected, will the car throw codes when this is plugged back in? Or will it be OK assuming I've given it an hour or so for caps to discharge after unplugging?
