MingMan,
Regarding the Ultra High Fidelity Sound System. It depends on your music source. If you plan on listening to high quality sources then the premium sound system is worth it. For example, you will be using the USB ports and music recorded in a lossless format like FLAC. If you will be listening to local radio or internet radio the signal quality is not that great. Consequently, the sound from either the regular or premium sound system is not that great either. If you do not plan on using good quality sources then the basic sound system may be good enough.
I have 500GB SSD drive with music recorded in FLAC format. I have recorded some of the same songs in MP3 format to compare and the difference is huge. If you go to the service center they have the ability to demonstrate MP3 vs FLAC recordings of the same music so you can hear the difference. Talk to Tee Wong if you want this demo. Or I can meet you and demo it for you on my car with the premium sound system.
Notes on upgrading: If you think you may want to upgrade later here in HK, then I suggest getting the factory premium system first and then investing in good quality music sources. In a comparison with someone who spent tens of thousands of HK$ to upgrade afterwards and it wasn't as good as the factory system except for thumping bass. He also listened primarily to internet radio. Afterwards he said he should have spent his money on better quality music than hardware.
