tomsax
I have a couple of Roadster HPWCs I could be talked into selling. They are the original Tesla versions, made prior to the ClipperCreek version. Unlike the ClipperCreek versions, they have an easy way to set the maximum charge rate.
Of course, you can always set the charge rate at a given location so that you charge at 30A even if you're plugged into a 70A charger.
Finally, 70A at 240V is 16.8 kW. That's 0.3C for a 53 kWh battery pack. According the Martin Eberhard's blog, A Bit About Batteries, guidance is to stay below 0.5C, so even the 70A charge rate is being nice to the battery pack.
With respect to efficiency, my original study found that charging around 30A was the lowest charge rate that didn't sacrifice efficiency. It got more complicated when I looked at a much larger data set, but the results were similar. We charged our Roadster at 30A when at home, and as fast as we could when waiting for a charge on road trips and our battery held up pretty well.
