Roadster turn signals stopped working
Discussion in 'Roadster: Technical' started by emachine, Mar 16, 2014.
  1. emachine
    emachine Member
    Issaquah, WA
    But hazards still work. Checked the fuses and they are fine. Voltage at turn signal fuse is 13v and change. I assume there are separate relays somewhere for turn signals versus hazards... anyone know the location of these?
    Cheers and thanks,
    --E
  2. tom66
    tom66 Member
    United Kingdom
    I think there's a PCB called the Switchboard in charge of managing this. It might be faulty. No light at all, or solid light?
    Usually, the hazards are an independent system for safety concerns.
  3. emachine
    emachine Member
    Issaquah, WA
    Nope, no light at all. I was hoping that there were old school relays somewhere. ^^ Probably will meter the switch at the steering column as well....
  4. EVGuy
    EVGuy Member
    Bay Area
    did you fix the issue, yes its either the switch pack, under the dash, or the switch at the column. What did you find out with the DMM.
