I have a 2014 MS with a panoramic roof. The problem is that I have a leak over the driver's seat. I pulled down enough headliner to see that the drain tube (which wasn't clogged) had come off the drain fitting. I re-installed it and although the roof leak is better, it's still there. I can buy the applique seal online and replace the set, in hopes that will fix the problem, but I can't figure out how to get the applique off. I seem to have the newer V2.1 applique, with the roof rack rectangles not on the edge of the applique. I've read that this type are held on by tabs, not glue. I tried to pry the rear up and it's tightly installed. I'm wondering if my late 2014 started using the newer applique, but was glued on. Any ideas?
