Looks like you have a standard grid-tied PV system using Enphase micro-inverters.Not necessarily. It depends on the installation:
We have a bi-directional metering system so we over-produce during the day and draw from the grid at night (or in bad weather). We are also registered with the local emergency authorities and the utility company as we can still keep pumping out our excess power even if a power line goes down. On the side of our house there's a huge cut-off lever in bright red so that it can be turned off in the event of technicians working on the lines. It just so happens that we are in the middle of our rainy season and we had a stormy day yesterday which led to a power out at 3.55pm. See the production graph below; it was a very erratic day with storms coming and going. It was cloudy and semi-dark but we carried on producing power and the "dip" in current caused my computer to restart but we didn't lose power completely as our neighbors did - the power out only lasted a minute or so but with clear skies we could have kept going with HVAC and everything so long as we had sunshine and the technicians didn't require we shutdown. Having said all that, it's quite possible that a bi-directional meter was just too expensive to install for one public charging station.
That's a good point, probably worth keeping an extra tank or two on hand, it won't go bad. You can also get an adapter to hook up the small torch tanks in a pinch.Except the tanks are one of the first things to go in an emergency. Those outdoor BBQs become the only cooking surface.
I don't wanna spoil the great thread, but did you notice the J1772 here:
That said, if another owner has converted their Roadster to J1772, I'd like to hear about it.
I talked to the Rangers about it. They said that if the Model S has a J1772, a retrofit kit will be available.
Huh? I think at this point we all but assume that Model S will have J1772 (perhaps through an adapter).
But why would Model S offering j1772 mean that retrofits for Roadsters would happen?
They already offer an adapter cable for the Roadster.
Related to the thread topic:
1.4 Million Without Power in California, Arizona, Mexico Blackout - ABC News
Related discussion at MNL:
My Nissan Leaf Forum View topic - What if there is no power to charge the LEAF?
I would take the plunge and convert my roadster to J1772 if the Model S uses J1772 as a primary charge port. It looks like 5 bolts on the charge port. Then make an adaptor plate using my 3d printer to prototype the plate and have a plate machined out of aluminum...
