whitex
A 3D printed one would be safer because it would not have the metal prongs. Using this one could actually be more dangerous than not having it at all in some situations. Without it, the child has to stick fingers in the holes, and when shocked the muscles contract and they'd pull them back out. With the plug, if the child attempts to pull it out, they'll likely end up sticking their hands such that they'll get a shock from the metal prongs. If they hold it in such a way where they are "grasping" the prongs, getting shocked will cause the muscles to contract and them not be able to let go. Hopefully the plug would then just pull out but those can be pretty tight sometimes and children don't have a lot of mass. Also, you could make the plastic prongs smaller so they don't wear out the outlet.I'm sure it would be, I have a 3D printer and considered it. With a plug from the store, anyone should be able to make one for whatever outlet they have in just a few minutes.
All that said, the proper safety solution is this:
$28 at Lowes: https://www.lowes.com/pd/Eaton-50-Amp-Overhead-Temporary-Power-Panel/3027570
You can then use a lock, or some child-safe locking device.
