Hope I'm wrong.
Let me first use simplified geometry to convey this hypothesis.
Imagine you're standing at the back of the MY. Imagine next that the car is a rectangle. The top and bottom(where you're standing), are the short elements and the left and right (driver and passenger side) elements are longer- say for this example, 2x longer. Now place a point in the middle of these long side elements.
OK, GULP, here we go...
If we shift the left element backward, say by an inch, we would now have a parallelogram. If the rear seat backrests can be thought of as two lines, each originating at the mid point of the side long elements and perpendicular to them, they will not connect in the middle. They would if we had a true rectangle.
I believe the early MYs are parallelograms due to a weld fixture problem early in the production line.
While this wouldn't effect handling it would cause all the body panel alignment issues we're seeing. It would also explain why they say there is no fix for the seat back offset.
I'm due to pick up MY in an 1.5 hours.
The first thing I check will be that rear row. I'm also gonna bring a tape measure and take some diagonal measurements. I will reject the car if there is more than 1/4" variance.
