Hi
I picked up a second hand M3P, 27000 on the clock, 2019, pre chrome delete.
First one I saw and test drove, was blown away by the performance and purchased on the day, so I know I did very little research. Ive driven an S and X occasionally in the past from a fleet of work vehicles so was expecting great software and some what less great build quality. It was a bit of a rush purchase as I had just bought the MG4 a few months prior but the software was so bad and dangerous, its just sat on the drive now and none of us will drive it (trying to get MG to take it back).
Ive made a list of things i've noticed and I hope some of your more experiences M3 owners can Gove me some quick fire responses to if they are warranty issues / can I fix them.
Hit a pot hole, both tires on that side needed to be replaced and the fitter said the alloys are also not tru, can this be fixed ?
Cracks in boot lid welding above the numberplate
moisture in rear light clusters
Boot does not lift up on its own - particularly in the cold, like the struts dont have enough pressure or something to life the boot.
Dent on bonnet, looks like a point load impact from something heavy but not sharp as its in the crease
Wireless charger unreliable - looks like its been retro fitted by the previous owner - any recommendations for a better one.
Range - Couldn’t manage 2x70mile trips at around 0 degrees from 100% charge
Some vibration or noise from axles/wheels, noticeable on smooth roads (assume tire and alloy balancing should fix)
Bonking noise like a piece of metal deforming from battery area during rapid charging and some times driving
Driver door handle slow to close meaning drivers door doesn’t latch in first go, particularly when cold
Driver seat rocks a little on acceleration and deceleration
Squeaky windows - very noticeable when doing the light show
I have a 7kw home charger (zappi) and in the morning, I cant seem to find a quick way to unplug the charge cable with out getting in the car and pressing a button, I just want to unplug and go.
I apologise, I know most the answers will be on the forum in some form or another, this just seems way more efficient for an experienced person to quick fire answer.
Thanks in advance, a very happy motorist.
