Is there a way to set your battery charge using numbers rather than the graphic provided? It seems pretty inaccurate using the slider over the battery image. Having a rolling number (like the way you can set the departure time) would be very handy,
If you use the Tesla app to set the charging settings you can see the numeric values for % of charge or estimated range as you adjust the slider left and right.
I normally use Teslafi to set the percentage exactly. I've set Teslafi as a favorite on the car's browser, it's a work around this silly limitation, but it just seems like it's a no-brainer to put that numeric wheel on the display as an option.
And, what if I'm pulling into a supercharger and only need to charge to 40%? Can't set that low a percentage with the graphic. (I do this to get home with the lowest SOC)
