These are konig dekagram in 18x9.5 +35mm wrapped with Hoosier r7. These are the A profile so they have better brake clearance. I was having a problem with the lip of wheel hitting the knuckle barely so I tried some different spacers but because of the lip on performance hub this became harder than it should have been. Then I found these spacers 3mm which go from 73(lip of hub) to 70.1 bore of the konig. Also, the rear calipers just abrely clear so you have to make sure they don't put your wheel weights in line with them. These work great because they essentially just sit flush on that lip and allow easy install of the wheel and the clearance you need. A lot of wheels with our lug pattern share that bore so it may help someone else. These were the lightest wheels for the price I could find. Here's the link for spacers as well. Hope this helps and don't mind my gap coilovers coming soon https://amzn.to/3elQ6TK
