So I ordered wheels from Tesery
I know others have been wondering how the quality is.
As far as I can tell they seem pretty good!!
I do believe they are forged, either that or they completely machined the whole wheel to remove the cast look.
I considered other brands but they all looked the same, mostly black, same design as titan 7 ($$$) or zero g.
We have potholes, frequent rain, and poor lighting so I wanted something with more sidewall than my stock 20s, went with the style 8 (Vossen look alike) with brushed finish in 18"x8.5 +30 offset.
Tires are Laufenn from Amazon (hope i don't regret it, tire rack had good reviews, could have gotten goodyear for same price).
Tires have no foam but don't sound any louder than my 1yr old PS4S with foam on the 20s.
I received them awhile ago but it took time for me to get the tires mounted an finally installed them on my car.
Weight difference, old stock 20" performance wheels with tires came in at 56.4lbs, these18s came in at 46.1lbs total.
the 18"rim by itself is 21.6lbs.
No issues with balancing the wheels as sometimes is a problem with MIC wheels.
Had to clean my hub bore to get the wheels to seat properly, slightly tighter fit than the factory wheels around the bore.
You don't have to remove the 10mm bolt that holds the rotor down, as you can see the wheels have a hole drilled for them, also the 3mm hub bore size change isn't a problem so no spacer is needed and it clears the performance brakes.
Downside is since im in Hawaii I had to pay $300 to have it shipped.
