I noticed the Iridium satellites and the GRACE sats both are very similar in shape and size (minus the Iridium solar arrays). Were they built by the same company or just a coincidence?
SpaceX does not use explosive bolts, they use spring-loaded clamps, I think. When the clamp release is triggered electrically the spring expands and gently pushes the satellite away from its mount.how they are released?
I think some of the clamps are activated by high pressure Helium, but that might just be the fairing.SpaceX does not use explosive bolts, they use spring-loaded clamps, I think. When the clamp release is triggered electrically the spring expands and gently pushes the satellite away from its mount.
Yes, Mercury had it's abort tests on Little Joe boosters and Apollo flew it's abort tests on Little Joe II. Then there was the unplanned test on the actual Mercury-Atlas 3 test flight. The Atlas failed to initiate it's pitch and roll sequence to head downrange and instead just continued flying straight up... until the RSO (range safety officer) sent the destruct signal. The launch escape system did it's job and the spacecraft splashed down just off the beach, and was reflown on MA-4.Has NASA or anyone ever done an in-flight abort test?
Wow, literally! Looks like about 100m offshore.The launch escape system did it's job and the spacecraft splashed down just off the beach...
Not that different from SpaceX abort test. That landed only about 100m offshore. 18:40 in the video.Wow, literally! Looks like about 100m offshore.
Hopefully not by pyrotechnics and breaking bolts?
