I ordered a spare set of front and rear brake caliper bleed screws from Tesla Mobile Service so that I can determine the right dimensions and thread sizes to replace the ones on my Model 3 LR RWD with speed bleeder valves. The original bleed screws for front and back have different part numbers in the parts catalog (front kit with 2 bleed screws is 8008256-00-A, and rear kit with 2 bleed screws is 8008260-00-A). It looks like the Performance Model 3 uses a different rear bleed screw with part number 8008262-00-A, but the front seems to be the same.
There are two different brands of speed bleeders that I looked into; Stahlbus and Speed Bleeder. The Stahlbus screw is a 2-piece system and the Speed Bleeder is 1-piece like the OEM bleed screws. An animation of how the Stahlbus system works is at the very bottom of this post. The Speed Bleeder is identical in the way it mechanically works, even though it's body is 1-piece.
Front bleed screws - I have received the OEM Tesla Model 3 front bleed screw kit (Part # 8008256-00-A) and measured it's dimensions as follows: M10-1.0 thread, 16mm thread length, 30mm overall length. The matching Stahlbus part is SB-110411, Stahlbus SB-110411. The matching Speed Bleeder part is SB1010S, and you get 3 choices between Stainless Steel, Black Steel, and Standard. The Speed Bleeder screws come with dust caps. The Stahlbus ones don't (so order the caps at the same time because the stock ones won't fit). I have attached a picture of the OEM Model 3 bleed screw kit.
Rear bleed screws - I have not yet received the OEM Tesla Model 3 rear bleed screw kit (Part # 8008260-00-A). When I receive them, I will measure them and find the equivalent Stahlbus and Speed Bleeder parts.
FrontBleedScrews
Tesla Model 3 front brake caliper bleed screw kit
SVC FR BRAKE CALIPER, BLEED SCREW KIT...
