Springfield MA to Poughkeepsie NY
Discussion in 'New England' started by andydoty, Jul 12, 2014.
  1. andydoty
    andydoty Member
    Massachusetts
    So I have to take a 1 day (trying to keep close to an 8 hour day round trip) to Poughkeepsie NY from Springfield MA. I'm trying to map things out albeit with little success. It appears my only option is to stop in Milford which makes the travel time 3+ hours each way (travel plus charge time). I would have to travel south to Milford CT then back north and then west to NY. I REALLY don't want to take my ICE, although, it would appear that I may have to. I've used Plugshare and Google to map out the trip.
  2. pbleic
    pbleic Member
    Boston
  3. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    If you drive conservatively and have a 85kWh battery, you should be able to do this trip without charging. It should take about 125 rated miles of charge each way, which is tight. There are three public chargers in/near Poughkeepsie (shown on Plugshare.com), so if you don't like your battery charge once you arrive, you have options to top up before you go home. If you're staying overnight, the Residence Inn with EV charging makes this dead simple.
