Squeaking noise from both front doors.
We are getting a squeaking noise from both front doors, the RH more than the LH. But only when hot outside. Anyone else experience this issue? Any known remedies? Ran a small amount of silicone on the top lip where the glass meets the rubber. Did not help.
So it seems the issue is that the door glass is not aligned properly or getting over tensioned when it goes all the way up. Any ideas on how to adjust the height or tension of the glass on close?
You could try and re-calibrate the windows. See the attached pic from the owners manual, page 15.
