It's officially the rainy season in the NW. So...yeah, the RWD LR is getting a little squirrely, "I can't use the POWER!"
This is where the AWD would answer. Nonetheless, I will sally forth boldly!
That's exactly right. You'll even get a little of the rear wobble if you hit a painted spot on the road under strong acceleration. And yes, traction control will "save" you, but the full available power of the M3 RWD simply can't be used on rainy roads. I do think there are probably some different tires that might help, but really, I just have to adjust to the reality of the conditions.When the tires are wet, the traction control lets you know that it isn't willing to go the way you expect from the dry.
Here is eternally sunny California, I feel hamstrung for a few blocks after getting a car wash.
Suggestions and have you done so yourself?You don't need AWD, just some good tires
??I'm more convinced than ever that my car is down on power compared to some peoples'…
Any sort of power-induced traction loss in the dry requires basically an act of god or heroic driver efforts in my car. In the wet it's still not all that easy, either.
Interesting. Well, I lose traction on a wet road if I use more than about 1/2 power from a standing start. Have you measured your zero to sixty time? It should be right around 5 seconds. If it's more than about 5.5 I'd take your car to a service center have them test it.Any sort of power-induced traction loss in the dry requires basically an act of god or heroic driver efforts in my car. In the wet it's still not all that easy, either.
Are they softer tires then? What about noise, ride quality, life expectancy?Michelin PS4S, and yes, I've had those on all my cars, before that they were called Pilot Super Sports. And then in the winter I use Pilot Alpins. I was just saying the best thing to add traction is tires, not AWD. You'd just be spinning 4 wheels instead of two.
I was more along the lines of nesting in the frunk.My first impression reading based on the title was his/her brand new Model 3 got damaged by running over the squirrels on the road.
Well, obviously if you apply the same overall amount of power to 4 wheels instead of just two you'll have twice the available traction to power ratio. My Eagle Talon Tsi was nearly impossible to break loose on wet pavement (that was about the only thing positive thing I can say about it. ) I imagine the M3 AWD has the same qualities. I'm sure someone that owns one can chime in here.Why is everyone disagreeing with this? I thought this was known.
