I just want to add my 2 cents: We installed hydronic heating 17 years ago and absolutely love it. We looked at the Warmboard product, but instead rolled our own system for costs. We put down 1/40" aluminum sheets on subfloor, and then cut 5/8" plywood into 8" strips with bevel, and put down the 1/2" pipe with silicone along the edges screwing the strips down snug to hold the pipes down against the metal.
With an outdoor reset system we really can't tell what the temperature is outside, it is simply always comfortable and stable inside. Well except for the tile floors in the bathrooms: if they feel warm to your feet then it is quite cold outside.
I guess I don't understand people here using term 'heat pump'. You can (we do) use a heat pump to heat the water just as easily as heating air for a forced air or minisplit system.
But using the water to distribute that heat through the house is far better in my opinion than blowing hot air on/off. Quieter, more comfortable and supposedly more efficient (~20%), at least that's what we were told doing the research 20 years ago. We have tall ceilings and in a forced air system, the hottest air would simply rise and heat the ceiling, the absolutely last place we want to be the warmest place in the house. So that does let us turn down the thermostat, keeping the things closer to the floor at a comfortable temp and not the ceiling.
In a This Old House show I watched a few months ago (the net zero remodel last season) there were using the hydronic system to also redistribute solar gain heat from the sun-warmed rooms to the cooler north side rooms. This kind of self regulation of heat delivery is built in. The colder rooms will suck more heat from the pipes than the warmer rooms simply due to thermogradiant. Forced air delivering N cubic feet of 100deg air per room can't do that, at least not without room level thermostats and motorized vent controls.
While ours is simply on wood subfloors, usually heating a large thermal mass is the whole point--it is much more comfortable. Most hydronic systems are installed in concrete for that reason. Nowadays, you can thermally decouple the slab from the ground well enough you aren't losing much out that way.
Anyways, that's our experience. I do hate forced air systems for the noise and blowing air. Always have. And doing it ourselves wasn't more expensive. Granted, the systems are pricey if you hire people to do it all but that would appear to us to be the only downside.
