Hi all,
I have an extra set of rims/wheels I am thinking for next years snow tires. They have the identical bolt pattern of 5X114.3. The centre bore on the Aero is 64.1 the substitute wheels have a centre bore size of 66.1. I purchased hub centric rings that will centre the hub. No problem there.
The other difference is the offset. The Aero rim offset is +40mm. The substitute rim offset is +55mm. They both take the exact same tire size of 235/45/18. Will the centreline offset difference be a problem? Anyone know?
Thank-you
Thank-you
