Sunpass
Discussion in 'Florida' started by tropical1, Jul 13, 2016.
Tags:
  1. tropical1
    tropical1 Member
    Odessa, FL
    Sunpass sent me a mountable transmitter. Does this need to be installed by Tesla on Model S or can I DIY.
    Thanks
  2. Racerx22b
    Racerx22b @unplggdd on Instagram
    West Palm Beach, FL
    If you're comfortable popping off the nosecone then it's totally a DIY. Tons of threads on here on how to do that. But if you're near a service center they can do it in just a few minutes. They installed mine when I picked up my car.
    I believe it's just zip tied to the steel beam behind the nose cone. It's nothing high tech. Mine works perfect there.
  3. Science->Truth
    Florida
    Yes, it's great with the hidden mount behind the nosecone. I think it's so much better than an (ugly) item on the top of the windshield. Only thing I noticed, is that when at the airport parking SunPass lane, make *sure* to stop firmly right as the rear wheels are on the speed bump. If you pull too far forward, the transponder will not read. I assume it's designed under the assumption it's at the top of the windshield. Once you know, it works fine. Just don't pull too far forward before the transponder is read.
  4. jbcarioca
    jbcarioca Active Member
    At least at MIA Sunpass is no longer accepted. The last time I parked there a few weeks ago the Sunpass signs were gone and one had to exit in the normal lanes.:mad:
  5. tropical1
    tropical1 Member
    Odessa, FL
    Racerx22b thanks for you response
    Jbcarioca I can't believe they don't accept it at MIA. All of the garage at Tampa Airport have it.
  6. jbcarioca
    MIA discontinued Surpass only a few weeks ago. Major bummer for me!
  7. DougNguyen
    DougNguyen New Member
    Tampa fl
    You can register your account via your plate only, no extra equipment needed, no extra fees either
  8. m2s2
    m2s2 Member
    florida
    I believe the new nose cones like in the X and new S do not have room forvtranmitter. Suction cut works through new windows
  9. Hookemhorns
    Hookemhorns Member
    Georgia
    Has anyone put one of the window stickers on the new refresh Model S? Just got mine, and wonder if that will work
  10. siraj
    siraj Member
    Fort Lauderdale
    I believe it's just zip tied to the steel beam behind the nose cone. It's nothing high tech. Mine works perfect there.[/QUOTE]
    Yes.. It works most of the time.. There is a spot by the rear view mirror.
  11. Rodolfo Paiz
    Rodolfo Paiz 55 Fidelius Family Office
    Miami, FL
    For those of you mounting transponders behind the nosecone, are you using the sticker transponder, or are you using the battery-powered box transponders? I thought the stickers were only for mounting on glass...
  12. Science->Truth
    Florida
    No, not the sticker transponder nor the small box transponder goes behind nosecone. Get the "license plate mounted" transponder and mount that behind the nose cone. Mine was installed by Tesla service center at new car pickup with two screws. If you are comfortable popping off the nosecone, its easy.
  13. Rodolfo Paiz
    Miami, FL
    Already had the nosecone removed. :)
    After catching up on all the threads, I've decided simply to go transponderless. I also checked with Sunpass and they confirmed that an ITOL transaction is billed at exactly the same rate as a TTOL. As long as I have a transponder assigned to my car, I'll get billed the same regardless of identification method. My thanks to them for being proactive that way, as it makes my life a whole lot easier.
